hi, the early AFB carbs didn't have weighted air valves above secondary bores. asfar as I remember, those were used up till 1966.
the 235 /273 had weighted valves starting in 1965. the 383 had none. lot of it depended on engine combo. AFB came out in 1960 ?? so you have early AFB carbs.
