I have a dozen of these carbs, AFB's, and none have the weighted valves above the secondaries. The secondaries are spring loaded, downdraft opens them on full throttle and forced closed by a lever when throttle is released.
If you have a dozen AFB's,can't imagine you have none with any of these.
