Thanks again. The pics definitely help.
yes you can use the 66-70 B-body V8 k-frame...remember there Are two different idler arms and two different sizes of steering gEAR BOX BOLTS.. My 66 was a S^ and i used a 68 Charger K-frame. your best bet is to rebuild front suspension at the same time. its pretty easy doing it on a work bench...
Are the bolts different diameters or just different lengths.
Lastly, is black the correct color for the k-frame?
