Thanks gentlemen. So, I assume a stock manual gear box will swap between K-members?
Yes it will.
Also get a 68 or 69 B body K member and eliminate the $$$ stud mount idler arm while you are at it.
E body and 71/72 B body have a different steering box mounting angle , along with a different swaybar mounting setup so just stick with the 68/9 K .
