I already have the Bruno and Lenco, just trying to figure out what gear sets I will need.
Looking at your profile, I see you've been running a TF in the Fury. If you're wanting similar ratios, you would need a 1.68% and 1.44% gearbox, that would give you a 2.42 first gear ratio. There are other combinations that will give you the same first gear, but you have to determine how much of a spread you want between 2nd and 3rd and then plug in the other ratios until you get the first gear you want. Not sure which Lenco (CS-1, CS-2)you have but here is link to all of the ratios available.
http://www.lencoracing.com/HowaLENCOworksandRATIOSmaster.html
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
