did you guys spray the copper coat on them between layers when they were new? I did on used ones
I just did the outsides to address any irregularities on the block / head surfaces. Assumed the other surfaces ( between layers ) would be good.
I did mine the same way and for the same reasons.
Jerry Williams.
