I have 2003 Hemi Ram. I had a metal on metal sound and no 4 wheel drive, The Half shaft and the Diff spline on my driver side was grinding ( both worn)
![](/ubbthreads/images/graemlins/frown.gif)
I'm replacing the driverside front Half shaft .... no problem. The spline which is about 8 inches is connected to the front Diff. I believe it's just supposed to pop out with some force. no need to remove the cover. I welded a chain to the old shaft and have tried leveraging it out.
![](/ubbthreads/images/graemlins/wrench.gif)
Question ... Is the slide hammer the only way to get that past the C clip ? Do I really have to manhandle that thing out? Thanks in advance.
