Since you should at least pull the pan to change the filter and oil you can see what has been done to the throttle pressure arm and valve body.
By the looks of the line connection and shift arm that tranny has been sitting for a while so a rebuild might be in order.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
