Quote: Are there any differences in the cabs between a standard cab and a crew cab - with regard to a visor fitting?
Yes...
72-80 Standard Cab, 73-93 Extended Cab and Crew Cab are the same
81-93 Standard cab are the same, but differ slightly from the others mentioned. The front of the cab above the windshield has a more pronounced body line.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
