Re: Tips for SS Spring Drag Cars
[Re: tazmaniac]
#15318
04/30/05 10:48 PM
04/30/05 10:48 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I switched to the 002/003with a 1/2 leaf on the passenger side, from the beefy SS springs in my Charger, havent test yet but from advice from Chuck Lofgren he said for a starting point passenger side one clamp right at the 1-2 leaf next to the hanger and one on the 2-3 leaf,driver side one clamp 1-2 leaf next to the shackle and a clamp on the 2-3, also about a 2-3 degree rake, level the car with the TB which will pre load the right rear because of the 1/2 leaf, 7 degrees pinion angle and a proper front end alignment
Ok I am trying to understand this..I am not to bright sometimes LOL..#1 spring is the main leaf or bottom leaf ? and hanger is that the front or the shackel in the back ? and does the 1/2 leaf on the passenger side toward the back or front ? Thanks...:)
