Which transmission is shown on the fender tag? I believe "3" is 4spd, "5" or "6" is automatic.
Does the 6 digit order# on the tag match the rad support and trunk lip stampings?
EDIT; might as well check your engine code also, "83" is 440HP. What is the code under "AX"?
