See if you can scare up a single plane intake for it. Those 2 little holes on the stock 2 bbl intake I'm guessing might be a lot of restriction. If it is I would expect you might see that 400 HP maybe a little more.
Kevin
He has access to a single plane M1 that's sitting in the garage...
