I am going to try a different seal retainer and have it milled 0.010 at the base, better gaskets, maybe the felpro race rear main seal, a new windage tray and a stock oil pump. I will clean everything with brake cleaner, lift the rear of the crankshaft up a little to make sure its very clean, dry and oil free. And I will use mopar ATV silicone.
I use a billet retainer on my last 3 motors. $69.95 MRE223 Cheap insurance when you consider all the extra work because the old wore stock unit leaks. ![](/ubbthreads/images/graemlins/Twocents.gif) oil leaks suck!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
