Quote: just got home and took some pictures. this is the housing that I have.... it doesn't look like the ones that you have pictured for me. these were supposed to have been out of a 69 Coronet RT.
Dave,
What you have is a center column bracket from a 70-4 E body, but fortunately the pedals you have and the side clutch bracket are 66-7 B body, close enough for 68-70 pedals, they will swap into your 70 automatic center section...someone must have tried to swap that stuff into an E body before you got it
