Yes, my problem is with the bracket that houses the pedals. my housing has the same shape as the welded bracket that I showed a picture of...even has the two threaded studs that stick down to bolt the column bracket to.
I'm not home now so I don't have any pictures of what I have. If I can transfer the pedals over then great!!
