Keep the motor under 450ci with the 6-71. To free up horsepower without cranking up the boost, get some ported conventional heads like Stealth, Edelbrock, etc. Use a mild cam like a Mopar 528 mechanical. locked distributor at 25deg, 8lbs boost and you'll be at 700hp with zero maintenance.
