Chip what front suspension do you have? I'm running stock. My car is also very nose heavy.
DodgeCharger...All stock stuff other than the shocks. It has poly bushings and I spent some time freeing up the UCA bushings so they weren't bound up like most are after being rebuilt. No LCA bumbers and extensions on the shocks for travel. My car is noseheavy too...don't have the numbers in front of me, but I can get em when I get home from work this evening to tell you the front and rear weights.
67DartGT...The Calverts may work great on a different application like you said. I've never tried them on anything else. I just posted my experience b/c my car is very similar to the OP's.
SSDart...the only change I made to my car was the front shocks. A stiffer/slower extending set of front shocks made all the traction problems go away.
Looks like the car works good........
