This can be maddening! A shop I worked at had a Camaro with a small block loosing coolant. Engine ran well enough, but lost coolant. Shop owner replaced the short block, had the valves ground and heads surfaced, still leaked. Finally found a crack inside a port. This was back when Chev small block heads were cast 3# lighter in Mexico. Blame the engineering not the foundry. Machine shop shared the cost, but no one won. Pressure test the assembled engine and then the heads and you will find it!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
