good luck are you runing the same header collectors
I cut off the collector all but where the pipes merg so the turnout that caused the reversion I believe is gone.I have 2.25" primary pipes.The shop with the dyno is one of the best header makers in the country so I hope for some input from him also.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
