Advance the cam 4 deg and rebuild your AVS. Want a few extra MPG? Go with the TQ too. Leave the stock intake. I doubt there is enough difference between a non high rise aluminum dual plane and factory iron to be bothered. Kevin
X2 X2. richen the AVS, tweak the dizzy curve. next step up would be HP ex manifolds/mandrel 2&1/2" system all the way back. Dynomax muffs also with free flowing glasspacks (for noise reduction) alongside the rear springs
