cool I did not see any replies on bbd I will check again the heated pitman arm works? do you have to do the same to the idler to make it even across the centerlink no crazy alignment issues or funky steering side effects?
Bending the pitman and idler arms will change your toe pattern. How much depends on how much you have to bend it.
Personally I'd look elsewhere for a clearance solution.
