Is the fuel tank and vents all hooked up correctly in back?
Where does your vent line end up at up front? On top of the engine by the thermostat?
t
73 has only 1 vent ,which goes to the canister marked tank.which is hooked up,do i hook the purge or bowl port marked on canister to full vaccumm on carb?
