There are a lot more cars out there than you guys realize. In the early 90's Dominic Durinzi and I started a Nostalgia Pro Stock Association with limited success. At that time the cars either looked correct or ran strong. Dominic's S&M Colt and the '75 Rod Shop Butler built Dart were the only Moaprs that could do both. Times have changed. Remember, there are plenty of Ford/GM P/S competitors out there too. The ground work has been laid. BTW how many of today's Nostalgia Max Wedge cars could could even come close to passing NHRA Stock Eliminator tech?
