Brian...
It works...Aside from being a VP fuel dealer, I have many dyno tests to prove the fuel does whats its supposed to..I have been using it since it first came out and worked with a VP engineer on getting up to speed on running this fuel safely and effectively. I have also recommended and worked through several other combos for friends and fuel customers that have run their best times on the Q16. These guys swear by it now..
There is special handling invoived..Jetting is important as is timing. Also some other more mundane stuff.
It is an IDEAL fuel for FAST type engines..Many of the records set might not even have been possible without the oxygenated fuel.
Call me if you want...I have a lot of experience and R & D with this fuel. It will work for you.
MB
Mike do you think I should go with Q16 or do you think the VP113 would be better suited? The motor is 13.5:1 with 250psi of cranking compression.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
