Possiably, As long as the motor was never rebuilt.
The numbers on the block will tell you what SHOULD be, not necessarily what is. I guess it could be another starting point.
The only way to tell if it is a forged or cast crank is from the casting lines on the throws.
You can also install the wrong Ba lancer on ether.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
