Re: Tire rules? -autocross
[Re: Mattax]
#1493409
09/01/13 12:00 PM
09/01/13 12:00 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
The reason you can't find the tires/wheels is because there is something wrong with the pdf. Pages 116- 131 don't show in normal scrolling. Go to Appendix A and scroll down to C Prepared. You'll see a refrence to rule 17.4 click that and it will take you to the 'missing' page.
Within the SCCA Solo rules, our A, B, E bodies fall into the following classes (warning I have not kept up with the details of all the latest changes).
F Stock (for stock v-8s) You can run DOT R comps, but that will be changing in the next few years. I'm 99% sure that older cars are no longer allowed in Stock class at National level events.
E Street Prepared (/6 or v-8) Bolt on engine mods (headers, intake, carb). Look in both the appendix and the rules set for restrictions. Restrictions will be on size, and how much they stick out from the original body panel. In other words, also check the rules for flaring.
C Prepared (/6 or v-8) Modified engines, no interior, etc. Tire rules as Gary described above. Slicks are pretty common amongst the most serious compeitors.
Street Modified: All the rules from Street Prepared but engine is free to modify.
Road Tire/ Street Tire classes. This may be available for our cars either locally or nationally. For example Philadelphia Region SCCA has a SP/SM Road tire class for all or most Street Prepared and Street Modified cars on 'street tires'. The specifics are in the Region's supplement solo rules."
Thanks! Lots of reading now.....
