The pedal, from what I saw...goes through the floor board with a solid linkage...to a bellcrank....and the forward movement is all with shafts. I wish I could put a cable on this setup and be done with it...its so easy....I may have to pull rank, get a 69 B-Body pedal and hammer and run a cable to the carb...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
