The inspiration came from this '54 IH fire truck I saw on ebay a while back. I like the long look with the big/little rollers - so I want to run 16 inch wheels up front and matching 22.5s in the rear; either stockers up front with big steel Budds painted shiny the same color as the truck, or matching big / little 10-hole Alcoas like on the fire truck. The bed will need to be higher to cover the rear wheels, but mine wont be sitting on the ground like the IH, so it should work.
