We currently run a 512 RB with out of the box EZ heads, and is making 700hp on pump gas. We run a solid mechanical cam, 10.7:1 pistons, and a 950 Proform carb jetted up at least 2 all the way around. The block was treated to a girdle and a big oil pan, but not much else...Our cam is about .670" but you can detune it with a mild street cam. I normally don't care for Eddy heads, and about where they flow fully ported are about where these start out of the box.
Dragula, what car is this motor in? What ET is it running and at what weight?
1970 Challenger, all aluminum 528 Hemi, HDK suspension, Tremec 5 speed manual
