Re: Putting bushings in ductile iron rockers?
[Re: Dodgem]
#1479964
08/08/13 10:48 AM
08/08/13 10:48 AM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If you're going to bore the rockers out, what would you use as a reference to keep everything square?
"bore" is probably the wrong term to use. You would either ream them or hone them out. Either way, it would be self-centering on the current bore. If you want to get into optimizing the ratio ... well, good luck with that.
When I said bore I meant "material removal". Boring .030" using a boring head on a mill is easy. You could also use a reamer, but if your hole is off or crooked compared to the rest of the rocker a reamer won't fix that, it'll follow the existing hole, whereas a single point tool in a boring head won't, it will cut true. Good luck honing .060" out, hope you have alot of time to waste on your hands.
I think building a jig and trying to correct geometry would be a much greater waste of time. In the end you'll just be older with a little more self-satisfaction but no performance gain. And you'd be surprised how fast a hone will cut those cast rockers !!!
