If you're going to bore the rockers out, what would you use as a reference to keep everything square? I have a set of Crane 1.5's that are galled and have been considering doing the same thing. I was thinking of using the adjuster nut hole to hold it in a jig, and then dialing in the bore and then clamping it? Does anyone know how Dvorak and RAS does it?
