Small block with over 500 passes, 12 to 1 414 W5- 325/240 cfm @.650, small solid roller 260/264 @.050 .685 lift 106cl on 106, max ported M1 small port, 2" spacer, race demon 1000, square jet 90s no pvs, short header 30" 1 3/4 to 1 7/8, 3.5 collector, we turn it to 7k, Intake runners has been very clean till now, starting to see signs of darkening in runners to carb base plate.... whats up with this????
Might be getting time to do a valve job... with the
bounce the valves take it might be taking its toll
EDIT
Or the spring are going weak and bouncing even more
