I currently have a 360 with a Weiand tunnel ram and I run two holley 370 cfm carbs. I had two 450 holleys that Summit racing recommended for a tunnel ram but I could not get them to run well. I probably don`t have the HP of your stroker. Maybe others here with a combo closer to yours would be of more help. Also I do not run progressive linkage and I have a holley hp mechanical pump. I have some pictures but not on this computer. I can post them when I get back home. I run 4.56 gears and frying the tires is not a problem. Once I got the car tuned in the throttle response is awesome. Actually the car gets loose too easily. The car is a 77 Volare with a automatic trans.
