On the springs iirc they used the same spring as steel hoods, hence the bow in the center.
-Daty
Ehhhhh ....the Trans Am cars each had their own unique springs specific to each application,....the hoods bowed because they were improperly strengthened to handle a spring load in the closed position
If you want/need lightweight springs for your hood contact Unlimited Products, based on the weight of your hood they can recommend the proper application needed, go to www.up22.com
Mike
