I would advise against any wiring system that doesn't allow you to terminate the wire ends at the fuse block.........some appear to be hard wired to the fuse block and you can only terminate one end of each wire.
I've had two cars with Ron Francis systems and I like them, their Bare Bonz would be a good choice for cars without a lot of accessories.
The INTERNET, the MISinformation superhighway
