Quote: I just changed out a .640 U/D, so I thought i still had it here, but must have gave it back to him.
Fresh custom ground Comp solid,right out of the package:
#1 1.9995 #2 1.9826 #3 1.9675 #4 1.9519 #5 1.7739
given those numbers and his from above ...
1.73 1.93 1.95 1.96 1.98
Bob should have been able to throw his cam in from across the room
I'm going to guess difference in measuring tools .
Bob I would take the shop up on his offer , he should have asked you for a cam when you dropped off the block for the build I think. Has your cam been checked to see if it's bent ?
Those clearances dont add up... that would be a TON of clearance on each journal
