OK guys,
the friend that put the 318 into my 72 Fury didnt get the hood on for six months. Had the air cleaner on it so the carb wasnt stuck at all. But it go into the crankcase and somehow into the cyls.
I ended up pulling the plugs and getting the engine unstuck. The water had oil in it so it didnt rust anything up. I did get it to fire on primed gas.
But there is still milky oil in it. What is the best way to flush it all out?
I was planning on draining it and adding new oil/filter then running it for a short time then draining that and putting new oil/filter in it for good.
Or is there a better way? Any help appreciated.
