on my 2002 Ram 1500 Heater/air switch. I turn the fan on high it works fine. I turn the switch to any other speed it doesn't I replaced the fuse under the hood. I take it out no fan speed. I put the new one in and only the high works. I took the switch completely apart and cleaned the contact, put it back together and still nothing but high works I do not want to be buying switches if that's not the problem thanks in advance
2005 Dodge 1500 Slt Hemi
2008 Chrysler PT cruiser
1984 Dodge D250
1978 Dodge D100 Adventurer
1964 Meyers Manx Dunebuggy
