Re: Need Advice On Choosing Carburetor , New Build
[Re: Dodgem]
#1448285
06/06/13 08:53 PM
06/06/13 08:53 PM
Posts: 12,298 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There is nothing wrong with an 850 DP with stock jetting as new! Carbs are calibrated to give 12.5 to 13. to 1 AFR at wide open throttle and 14ish at part throttle. carbs do not know what is under them only how much air is being pulled through it.
Anyone who washes the walls has problems and no crab tuning and fixing skills. washing the walls would indicate floats to high, blown power valve, bad gaskets and so on.
870 is a good choice if you intend to do some racing then I would lean to a 850 DP. new or at least properly rebuilt and set up.
many get a carb then their expert buddies talk them into jetting it up 10 sizes cause it's a "race motor" I could tell you stories.
Have you ever plugged in a wide band while running an 850 DP? There is no way they cruise in the 14s OOTB.
Most of the carbs we are talking about will be 13ish at WOT, so that is not an issue with either a street or a race oriented carb.
What do you think is the difference between a race oriented and a street oriented carb? Nearly all carb companies build carbs for street duty and other carbs for the track.
There is a reason for that. Most of our street cars (not all, but most) will like 14.5-14.7 for a cruise ratio. And on the cruise circuit is where a street engine spends a good part of it's time. Even most of the street carbs will start a little on the fat side of that just for safety's sake.
But any race/track oriented carb will be considerably fatter than that. A lot of times in the 13's at cruise. And that will wash down the walls and foul the gas. Guaranteed!
Bottom line: either style of carb can be made to work good. One will just start off a lot closer than the other.
Master, again and still
Entire Thread
titan
06/06/13 03:37 AM
Brian Hafliger
06/06/13 06:20 AM
dogdays
06/06/13 06:30 AM
bentwheel43
06/06/13 02:10 PM
Cab_Burge
06/06/13 06:52 PM
DaveRS23
06/06/13 02:48 PM
dogdays
06/06/13 05:53 PM
Cab_Burge
06/07/13 06:58 PM
DaveRS23
06/08/13 01:35 AM
Darryls-Demon
06/08/13 02:31 AM
BSB67
06/08/13 02:43 AM
68HEMIRR
06/11/13 04:45 AM
rickseeman
06/11/13 02:19 PM
Dodgem
06/06/13 06:11 PM
DaveRS23
06/07/13 12:53 AM
Thumperdart
06/07/13 03:21 PM
BSB67
06/07/13 02:00 AM
383man
06/07/13 03:07 AM
