Mass
Gene, Thanks for the invite. I do appreciate it. However, the last time I did that it only got me into a HUGE "discussion" on this board that ended up getting the post locked and started a whole bunch of hard feelings. So, that being said, thank you, but I thought it better to not bother you guys. If I remember, wasn't there a guy there anyway? I didn't want to interrupt you.
Now to some math:
Here is my biggest problem with you guys saying that the ratios in our trans are so wide.
1st to 2nd gear change is 1.07 in our unit. It is 1.00 in yours. Maybe I am out in left field, but I really don't call that tremendously different.
2nd to third gear change is .59 in our unit. It is .61 in your unit. So, you are actually wider there. Again, I am not going to say that you are tremendously wide either. But in fairness, I never claimed that you were.
3rd to 4th is .20 in our unit and .28 in yours. AGAIN, WIDER!!!!!!
Yes, you have a 4th to 5th gear shift. However, when talking ratios, that is not relevant. In my opinion, the ONLY thing that you guys have over us is a taller OD. Which is fine, however, it seems to me that strength might be compromised by doing this. That is why we didn't make a steeper OD. We were concerned about making the stongest unit we could. Regardless, I have not personally had ANYONE call me complaining that the OD was not enough.
Now, I know the story of the transmission fixture breaking at 1400 lb/ft of torque, but lets be serious, if this were the case, a tremec trans would be virtually IMPOSSIBLE to break. I think that we both know that his isn't the case. I find it wierd that if they can take 1400 lb/ft of torque, then why are they rated at LESS THAN HALF of that number???? I know this, If my unit could take 1400 lb/ft of torque, I sure as heck would not rate it at less than half of its capabilites.
By the same token, I am not saying that one of our units is unbreakable. BUT, I am quite confident that it will take more than 600 lb of torque.
Lets look at another aspect here.
Howabout how steep your 1st gear is?
The final drive ratio in each gear is calculated by multiplying the transmission gear ratio by the rear end ratio. I picked a generic ratio that is a good rear ratio in a car that is a candidate for an overdrive. So, lets do some more math.
Your first gear: 2.89 X 4.10 = 11.84 final drive Our first gear: 2.66 X 4.10 = 10.90 final drive
That is a .94 difference. The way that you guys talk about how crappy our ratios are, this is a MONUMENTAL difference in gear ratios. No wonder why no one mentions it. So, why isn't anyone pointing this out??????? It seems like a relevant point to me.
Let me also say, there is not personal attack here at all. It is simple math. I am just amazed at how you guys "gloss over" the tremec's shortcomings and point out that our unit has such a horribly wide gear spread. The fact is: IT DOESN'T.
Jamie
Better watch out guys!....the waaambulance is just around the corner
Seriously, Keisler and Passon make GREAT products and offer GREAT service!.......and it's different strokes for different fokes.....the about gear spreads is rather ......I personally enjoy the Keisler gear ratios, esp the .64 OD.....there's nothing out there to compare with this!....nothing!
Of course Keisler gets my "Kudos" all day!.....but if I was building a totaly stock appearing 4spd car.....I'd go with a Passon box, for the ability of an OD in a stock case.......but again, it comes down to what the owner has in store for his/her car.......a forum pissing match really isn't going to sway a customers finial decision
