Quote: off topic, but yer lookin fer speed, right? I would look into a taller sixpack style scoop, if you are willing to consider it. I don't know exactly how much it is worth, but there are scoops built two inches higher to get above the boundry air layer better.
To find out if he needs more air he can tape some cardboard to the front of the scoop to bring the inlet to the front of the hood... with the top edge of the inlet a bit longer on the top to hang out just a bit.. seal it to the hood... that will pick up more air
