Quote: Check the plugs on the bulkhead connector. My roadrunner used to go dead like that and when I wiggled the lower one everything would come back on, I took it apart and cleaned it and made sure all ends were good and put dielectric Greece on it and its been fine.
Besides kleening the bulkhead tab connectors.. Tighten down the female connectors, by slightly pressuring down with long-nose pliers.. After 40 years, the bulkhead connectors can loosen and get alot of oxidation..
