looking at the multable arms and brackets that came with mine, it does have a shorter mopar arm,but it has a plastic bushing in it like the late modle mech linkage has, pops into the plastic bushing.
I assumed the little lug on the cable would not fit in it as it is a popit bushing and tthe older style used just the hole and rod.
I will dig it out and have another look at it.
i know the 1 I used had B&M stamped into it. and seems I have a lever on the stepside with mech linkage with the same B&M stamp.
I will dig out the stock levers and see how they compair to the hurst pieces.
yea stumpy..what lever did you use with yours? do you have slop in the cable?
