I did prime the oil and had my son turn the crank when priming to fill the crank. How do I get gas to the carb with a mechanical pump? The carb I am starting it with was off the running 318 last fall. Just using it for the start up. I plan on putting a rebuilt Holly on it but don't want to deal with the carb problem on start up.
