I have never had enough power to do the damage I am seeing here. I have broken extension housings and blown the servos out of the case due to bad or badly installed snap rings. It seems to me you might be wise to invest in either a PG or a TH400 with an Ultrabell. There has to be a point where it just makes sense to change, but I don't know where that is.
I'm way past that point.You'll never see a GM trans in my mopar,I won't give up my pushbutton shifter!! ![](/ubbthreads/images/graemlins/whistling.gif)
HEMI-ITIS has no cure. My condition is fully BLOWN!!
