I have an injector or injectors going bad. I would like to know if I need to do anything special to replace the injectors? I have 184k on the truck
They are due. Especially when you consider we have no sulfer in the fuel and that is the lubrication. I run used engine oil as an additive...They can be a real pain to get out. I did not swap out my last set, but the mechanic that did said they are a pain to get them out if they are the originals. You will chit when you get the new ones in...Will run like a scoulded monkey...
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
