slip yoke built into the drive shaft or slip yoke like a auto/4-speed?
is that a 1/2 to 1 from botooming out or comeing apart?
front rear shaft?
slip yoke like a auto/4spd you slide the slip yoke on the spline's.. I think it's to long, there is maybe 1/2" of travel from the slip yoke to the drive line, now what I was thinking is maybe cutting 1/2" off the spline's on the drive line, I don't want to cut 1/2 of the drive line it's self an weld it back up ect, I talked to a drive line shop an said they have done this before.. what do you guy's think?? an 76 I used the inspection plate but I think I got another let me dig around..
drive fast, drive hard, DRIVE MOPAR
