Thanks for the replies.
Using the waterborne because it looks to be working well. I can spray it myself without an air supplied respirator.
regardless of H2O paint you'll need a respirator. are you doing a base / clear application or is it a single stage paint? Lots of clears are still solvent based so you'll still need very good ventilation along with a respirator, doesn't have to be supplied air if you have adequate air flow.
Dawn dish soap works really well as a first stage washing & cleaner, after that wipe down with a wax a grease remover then shoot epoxy which BTW is solvent based - at least what I've used and as a positive it doesn't have Isocyanates.
