Finally getting back around to working on my Valiant and I'm planning on changing gears sets soon since my old handy work has made my 3.55 whine I want a better gear for cruising and I have considered a 2.76 but with the 28" tires when I'm at the track I'm alittle worried about making my 60' worse than it already is. Would you go with a 2.94 or a 2.76? I plan on doing drag week next year when my 360 is in the car so I need a good highway gear that won't sacrifice too much at the track. It will also be getting a powerglide more than likley this winter with a transbrake so I should be able to spool pretty good off the line.
I dont think your gonna see any difference of those
2 gears... Scott on here with the 62 4 door with the
turbo has a 2.76 in his car now but I dont recall
what his 60' is and I dont know what pressure he
leaves at... all I know is its still set up pretty
low(if I recall he maxes out at 10psi)
