You can either tap the housing and make a bracket or make a bracket that reaches all the way from the tube. The other way to get a speed sensor in the car is to mount one on the transmission yoke and make a bracket off the tranny.
The problem with mounting it on the trans and slip
yoke on the drive shaft moving in and out... if its
on the pinion yoke they stay as a constant to each other
